  Visitors: 3699
CAD tip CAD tip # 3735:
How to print several DWF sheets on a single page.
A - answer In DWF Viewer you can print multiple sheets at once from a multisheet DWF6 file.
Use File > Print (Ctrl+P) and in the Print Range option select Sheets and enter sheet numbers or number range - e.g. 1-5. Many printer drivers offer a "N-up" function which can nest several pages (2, 4, 6, 9...) on a single page. Using this driver option you can print multiple sheets on one page.
DWFVolo
19.4.2004    9305×
Prices - CAD eShop:
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
Tip 10182:How to create a PDF file from DWG without AutoCAD?
Tip 9998:Automatically rotate drawings plotted from Revit or other software.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
