  Visitors: 6025
CAD tip CAD tip # 3838:
How to find what is stored in which layer?
A - answer Especially with large drawings you may need to find (and display) quickly which objects/entities lay in a particular layer.
To find this you can either use the LAYWALK tool from Express Tools or a part of the LAYTRANS command. In this command, set the 'Show layer contents when selected' option under 'Settings...'. After you select a layer (or layers) in the 'Translate from' list, the drawing will display only contents of the selected layer(s). Exit the dialog with Cancel. Another method is the SHOLAYER utility (see Download).
ACAD2004ACAD2005ADT2005Map2005
31.5.2004    12158×
Prices - CAD eShop:
Tip 14033:Clipping blocks, images, curves, xrefs - everything, into any shape
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13858:Is there also a SETBYBLOCK command?
Tip 13822:Fast layer visibility toggle ON/OFF.
VRMLout More info
