  Visitors: 2521
CAD tip CAD tip # 3916:
How to load LISP files automatically into AutoCAD session?
A - answer If you want to load your .LSP applications into every AutoCAD session, add them (either by copy/paste or by invoking the (load "myApp.lsp") command) to your ACAD.LSP (or ACADDOC.LSP) file (use a text editor, e.g. Notepad).
NB: ACAD.LSP is loaded only in the first session unless you have ACADLSPASDOC set to 1.
Or - in a simpler way - use the 'StartUp Suite' in the APPLOAD dialog. You can even just drag your LSP file from Windows Explorer to the Briefcase icon in the APPLOAD dialog.
ACAD2000ACAD2004ACAD2007ADTMap
19.7.2004    102639×
Prices - CAD eShop:
Tip 12120:Double-click to edit raster images in DWG drawings.
Tip 11847:Automatic UCS aligned with the current View (UCSauto switch).
Tip 8823:Import of IGES, CATIA, Pro/E, Solidworks, NX files in AutoCAD 2013-2015.
Tip 8794:Display CAD model in true size 1:1 on your monitor.
Tip 7944:Automatic installation of AutoCAD 2012 add-on applications.
