  Visitors: 5652
CAD tip CAD tip # 3939:
Do you know the DROPGEOM command? (drag right-click)
A - answer One of the less known functions of AutoCAD is the ability to drag drawing objects using the right mouse button.
Select an object (or objects) using grips and drag it (not on a grip) with the right mouse button pressed to another place. When you release the button a context menu is displayed with options to Move, Copy or Paste as Block (or Cancel).
ACADADTLTMDTMap
26.7.2004    16344×
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12046:Random shape and appearance of an Inventor part or assembly.
Tip 11914:Maze generator for AutoCAD.
Tip 9743:How to use XY coordinates from Excel as polyline vertices in AutoCAD?
Tip 8852:Publish interactive 3D models on the web with Autodesk 360.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
