CAD tip # 4020:
Tip 13996: | Automatic hide for Revit palettes - save screen space (undocumented). |
Tip 13977: | How to publish a PDF to the same folder as a DWG drawing in AutoCAD? |
Tip 13948: | Undocumented function for quick block attribute editing - directly edit an attribute. |
Tip 12201: | Quick dynamic measuring of objects near your cursor. |
Tip 12118: | Easy frames and tables in Revit text annotations. An undocumented trick. |
How to print on HP DesignJet in Windows XP?
"NN were not able to be exploded" while exploding blocks - can't explode block. « | » Simple CAD network license borrowing for mobile users.
