  Visitors: 7206
CAD tip CAD tip # 4023:
"NN were not able to be exploded" while exploding blocks - can't explode block.
A - answer or "1 was not able to be exploded"
Older AutoCAD versions cannot explode blocks inserted with non-uniform scales (X/Y/Z) or inserted as MINSERT.
Try to set EXPLMODE variable to 1 and retry. You can also use the XPLODE command.
Your unequally scaled blocks may also contain 3D solids, surfaces, or regions, or may be part of a Group. Try to set the block scale to uniform scale. Some add-on applications can also prevent exploding your blocks.
AutoCAD 2006 (and higher) can assign the "can be exploded" property individually to any block definition (unexplodable blocks then display "could not be exploded") - see the Properties palette (Ctrl+1) in BEDIT mode.
ACADLTMapADT
17.9.2004    34835×
Prices - CAD eShop:
Tip 12569:How to Explode a ViewBase generated from a 3D model?
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Tip 11757:How to change blocks properties ex-post: annotative, allow exploding, scale uniformly
Tip 11497:Automatic grouping of drawing objects.
Tip 10574:Four methods for exploding blocks in AutoCAD.
