  Visitors: 4835
CAD tip CAD tip # 4126:
Extend and Trim commands display the message: "Edge is perpendicular to UCS XY plane."
A - answer Try to set PROJMODE (projection mode) to 0.
ACADLT
15.11.2004    16816×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 12966:TrimArr - trim a dynamic array to a boundary curve.
Tip 12348:Is it possible to import SketchUp SKP files 2013, 2018,2019 or 2020 into Revit?
Tip 12143:ATrim - dynamic trim/extend by painting.
Tip 12013:How to trim 3D solids with other 3D solid (3D trim).
Tip 11608:Trim to rectangle - cut out a part of a DWG drawing.
Simply link AutoCAD LT blocks to Excel table data.
Excellink LT 2006 More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
