CAD tip # 4161:
applies to: Revit 7 · |
Tip 14041: | Displaying the dimensions of equal repeated segments in Revit (EQ). |
Tip 13243: | Steep terrain surface change at a retaining wall. |
Tip 13163: | Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD) |
Tip 13032: | How to prepare a 3D model for manufacturing by removing detailed elements? |
Tip 12624: | How to enter dimensions in Revit using other units? |
How to communicate between AutoCAD and POV-Ray?
Does AutoCAD support multi-part solid bodies? « | » Entering "x" in Inventor dimension text displays "dp".
