  Visitors: 4975
CAD tip CAD tip # 4221:
Deferring IDW updates in Inventor.
A - answer To defer updates in a .IDW file (for a better performance) you can set this option in the IDW file open dialog - select the file, click on the Options button and check Defer updates. Do not forget to update the drawing views manually on model/assembly change.
You can also defer updates on the current drawing - see the menu: Tools > Document settings > Drawing tab
Inventor9
31.1.2005    9512×
applies to: Inventor 9 ·
Tip 12214:How to set bitmap transparency in an Inventor drawing.
Tip 11959:Supported file types (applications) with reference detection in Autodesk Desktop Connector.
Tip 11570:How to create an Inventor drawing from a photo?
Tip 11542:How to reset the top browser node name back to the file name?
Tip 10279:Which formats can be exported from configured models in Configurator 360?
LogOff 2006 More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
