  Visitors: 5652
CAD tip CAD tip # 4282:
Splitting the enterprise (fixed) and user (customizable) part of AutoCAD menu.
A - answer In AutoCAD 2006 and higher you can split menus (and toolbars, shortcuts) into a fixed (non-customizable) and a user (easily customizable) part.
For this you can use the "enterprise" CUI file (shared on your company network) and the standard user CUI menu file, combined with the ENTERPRISEMENU variable.
More details can be found in AutoCAD help - see the link to AutoCAD 2006 help (if you have it installed).
ACAD2006ADT2006Map2006
15.3.2005    6892×
Prices - CAD eShop:
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13620:How to quickly rotate the view by 90° in AutoCAD LT?
Tip 13529:How to redefine the behavior of a standard AutoCAD command?
Tip 13274:How to switch the DWG TrueView viewer to the classic user interface, without ribbon?
