  Visitors: 3370
CAD tip CAD tip # 4306:
What are the AutoCAD .XPG files?
A - answer XPG files are toolpalette group files which can be exported/imported from the CUSTOMIZE command in AutoCAD 2006 (right-click on a palette group in the palette tree). XPG files are in the XML format and can be used to transfer parts of tool palettes between computers.
ACAD2006ADT2006Map2006
22.3.2005    12056×
Tip 12215:How to change truecolor DWG objects to indexed ACI colors?
Tip 10365:Coordinate Tracker vs. Track Coordinates - how to track XYZ in Civil3D?
Tip 10139:Physical units conversion tool in an AutoCAD palette.
Tip 10015:How to select and modify objects in ALL layouts of the DWG?
Tip 9625:How to color 3D topo surface model by slope?
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
