  Visitors: 8240
CAD tip CAD tip # 4341:
Circular stairs with landings.
A - answer To create a spiral stairs with landings in Architectural Desktop, use the following settings.
In the Stair styles dialog, on the 'Landing Extensions' tab, set the desired 'Landing Length'. Insert circular stairs. Set the desired height method and value. In the 'Flight height' parameter (the Properties Palette) set the 'Flight Height Maximum Limit' value -- Architectural Desktop automatically inserts the required number of landings. If a landing is not inserted at the exact height you can move it by dragging the 'Move Auto Landing' grip in a 3D view of the selected stairs.
ADT2005ADT2006
10.4.2005    30982×
Prices - CAD eShop:
Tip 10459:How to change the number of parallel treads on spiral stair?
Tip 5005:How to add railing to an existing stair?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
