  Visitors: 3992
CAD tip CAD tip # 4350:
Computed values in AutoCAD table cells.
A - answer In tables (TABLE objects), AutoCAD 2006 supports mathematical expressions similar to MS Excel - you can use expressions (formulas) like e.g.:
=sum(A1:A27,C1)
=(a6+d6)/e1*8
=log(100)+sin(a5)
=average(B4:C4)
Contents of such computed tables is transferred to older AutoCAD versions in a form of results (as in fields).
ACAD2006ADT2006Map2006ACADM2006
13.4.2005    7105×
Tip 13006:Calculated property descriptions (tobogan slide from floor to floor)
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12777:Arithmetic and trigonometric functions available in Revit expressions.
Tip 12470:A table with calculated expressions is suddenly dead, doesn't calculate and update.
Tip 11994:How to scale a 3D model to a given size in Fusion 360?
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
