  Visitors: 7351
CAD tip CAD tip # 4425:
What is the difference in stretching an arc with the square or triangular grip?
A - answer Grip editing of an arc in AutoCAD 2006 offers either the square grip (dragging changes the radius, keeping the endpoints anchored) or the triangular grip (dragging changes the radius, keeping the included angle, endpoints are offset).
Similarly the triangles on the arc endpoints can lengthen the arc in the given direction.
ACAD2006LT2006ADT2006Map2006
18.5.2005    8806×
Prices - CAD eShop:
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 12755:How to create a polyline with multi-colored segments?
Tip 12501:Dynamic associative array of elements along a curve.
