  Visitors: 11716
CAD tip CAD tip # 4440:
HP Instant Printing from Autodesk DWF Viewer / Composer.
A - answer Autodesk DWF Viewer 6 and DWF Composer 2 (and higher) support the "HP Instant Printing" technology which simplifies printing of CAD data on HP DesignJet plotters.
If you print your DWF file and select a supported HP DesignJet model, DWF Viewer/Composer displays a new option "Use HP Instant Printing". By checking this option you can substantially simplify the print dialog and add a new HP direct print icon to your toolbar. Now even non-technical users can easily print CAD drawings.
HP Instant Printing automatically prints all sheets from your DWF file, in either full or half or fit scale (set automatically by media size, scaled sheets marked by watermark).
ACADDWF
100% *  CAD,PLT
25.5.2005    13249×
Prices - CAD eShop:
applies to: AutoCAD · DWF/Design Review ·
Tip 13773:What is the maximum paper size when plotting from AutoCAD?
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
Tip 10182:How to create a PDF file from DWG without AutoCAD?
