  Visitors: 4197
CAD tip CAD tip # 4445:
How to insert and rotate a block from a Tool palette?
A - answer If you want to be prompted for individual rotation angle on blocks inserted from a Tool palette, set the "Prompt for rotation" property for that particular tool.
Right-click on the tool and in its Properties set "Prompt for rotation = Yes". Insert such blocks by clicking not mouse-dragging.
ACAD2005LT2005ADT2005Map2005
27.5.2005    14896×
Tip 12215:How to change truecolor DWG objects to indexed ACI colors?
Tip 10015:How to select and modify objects in ALL layouts of the DWG?
Tip 7689:How to change path of a block referenced in an AutoCAD palette?
Tip 6630:Where are the landscape objects for AutoCAD 3D render?
Tip 5976:Keyboard shortcuts defined in AutoCAD.
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
