  Visitors: 10231
CAD tip CAD tip # 4482:
CUI: MNU/MNS Conversion failed.
A - answer Exception: System.NullReferenceException: Object reference not set to an instance of an object. (menu_yyparse)
The converted menu file has probably wrong internal structure. E.g. the individual menu items may share non-unique ID/Names, missing Menugroup name, improperly used <- ...
Fix your .mnu/.mns file and retry the conversion into CUI.
ACAD2006LT2006
21.6.2005    14552×
Prices - CAD eShop:
applies to: AutoCAD 2006 · AutoCAD LT 2006 ·
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13529:How to redefine the behavior of a standard AutoCAD command?
Tip 13274:How to switch the DWG TrueView viewer to the classic user interface, without ribbon?
Tip 13141:Screenmenu also in new AutoCAD versions.
