CAD tip # 4535:
applies to: AutoCAD · |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 13858: | Is there also a SETBYBLOCK command? |
Tip 13450: | How to create a complex line type with text always upside down? |
Tip 13435: | Bulk setting of layer properties according to the object in that layer. |
How to perform "Match Properties" for AEC objects?
How to revert back the old COPY command - no "Multiple". « | » Why is my Revit menu item Export 2D DWF grayed out?
Featuring: DwgTextTranslator translates a series of drawings from one language to another using MS Access. Download a fully functional trial version. |
