  Visitors: 3653
CAD tip CAD tip # 4610:
How to create terrain profile in Map 3D?
A - answer Autodesk Map 3D (unlike Civil 3D) doesn't support terrain 3D profiles (DTM sections) by default.
Use Autodesk Civil 3D or XANADU's add-on utility - Map3Dprof (see www.cadstudio.cz/map3dprof).
Map2006Map2005
31.8.2005    13156×
Prices - CAD eShop:
Tip 13243:Steep terrain surface change at a retaining wall.
Tip 12988:Where are Autodesk Infraworks building, road and terrain models loaded from?
Tip 12847:How to make transparent mask for raster maps in Autodesk Infraworks?
Tip 12222:How to find elevation (altitude) of a given point on Google Maps?
Tip 11511:Assigning elevations to 2D contours (isolines).
