  Visitors: 5107
CAD tip CAD tip # 4624:
Setting tolerance for automatic drawing cleanup.
A - answer You can set the tolerance for automatic (or interactive) cleaning of drawing inacurracies (duplicates, undershoots, overshoots, shorts, dangles, curve simplification...) with the MAPCLEAN and ADEDWGCLEAN Map commands. Errors under this tolerance level will be corrected.
Set the Tolerance value in the "Cleanup parameters" field on the "Cleanup actions" tab of the MAPCLEAN command, or by the option Options/Edit/Tolerance of the ADEDWGCLEAN command.
Map
7.9.2005    14180×
Prices - CAD eShop:
applies to: AutoCAD Map 3D ·
Tip 13221:Attractor - snap multiple objects to existing points/vertices.
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
Tip 12933:Purging small objects from a DWG drawing - PurgeSmall.
Tip 12303:3D model reconstructed from a series of photos has holes in it. How to fix it?
Tip 10416:How to fix/repair large 3D mesh models?
LogOff 2006 More info
