  Visitors: 11457
CAD tip CAD tip # 4634:
How to find the area of 2D Solid entities?
A - answer Convert your solids (no bowties) to regions with the REGION command. The "region" type objects already have the "Area" property.
ACAD
14.9.2005    7605×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13809:AutoCAD displays continuous lines and texts as dotted.
Tip 13805:Projecting/embossing a profile on a curved surface in Fusion 360.
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 12721:Animation of 3D milling along a path in AutoCAD.
Tip 12633:Sol2SolH - convert DWG objects of the type Solid to Hatches
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
