  Visitors: 3538
CAD tip CAD tip # 4656:
AutoCAD Plot dialog starting slowly.
A - answer Most of the reasons for slow start of the print dialog are related to network.
E.g. you may have too many plot styles saved/searched on network drives, or there is a problem in your LAN/WAN connection (congestion, faulty LAN card...), or you may have installed a network printer which is no longer available (and AutoCAD waits for its timeout).
ACADLTADTMap
28.9.2005    14522×
Tip 12951:How to disable DirectX 12 in AutoCAD 2022?
Tip 12701:What is the maximum length of a list in AutoCAD VisualLISP?
Tip 12448:Pan view (change view target) in multiple viewports of a layout.
Tip 12143:ATrim - dynamic trim/extend by painting.
Tip 12127:AutoCAD slower after obeying the recommendation from DELL Precision Optimizer.
LogOff 2006 More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
