  Visitors: 6647
CAD tip CAD tip # 4686:
Hatches are not displayed in long walls.
A - answer The hatchure is too complex. Increase the "MaxHatch" setting (environment variable) - in your AutoCAD commandline, type in:
(setenv "MaxHatch" "1000000")
In AutoCAD LT use the command SETENV
In newer AutoCAD versions, see also the variable HPMAXLINES.
ADTACAD
18.10.2005    6898×
Prices - CAD eShop:
applies to: AutoCAD Architecture · AutoCAD ·
Tip 14017:Voronoi diagrams in AutoCAD.
Tip 13960:Fermat's spiral in AutoCAD.
Tip 13802:Dual-color hatches in AutoCAD.
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
Tip 13590:How to set the hatch background color?
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
