  Visitors: 12761
CAD tip CAD tip # 4753:
How to dimension an angle larger than 180°?
A - answer For angles >180 degrees (up to 355.99 degrees) use the "specify vertex" option of the DIMANGULAR command.
On the first command prompt press Enter, pick the angle vertex and follow the prompts to specify the other two points.
ACAD
29.11.2005    20660×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13411:How do I set tolerances for several dimensions at the same time?
Tip 12697:Opposite angle for angular dimensions in Inventor drawings (iLogic).
Tip 12651:How to insert an aligned view into a Fusion 360 drawing?
Tip 12624:How to enter dimensions in Revit using other units?
Tip 12201:Quick dynamic measuring of objects near your cursor.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
