  Visitors: 4497
CAD tip CAD tip # 4780:
How to measure polyline length in AutoCAD LT?
A - answer There are several ways to display the measured length of a line, pline or polygon in AutoCAD LT.
You can pick and sum up the individual vertices through the DIST command; you can use the AREA command (gives the full/closed length); the LENGTHEN command; or open the Properties window (Ctrl+1) to display the length (and optionally copy/paste it to the drawing, Excel or other application).
To sum-up lenghts of many lines (per-layer table) you can use the "Report Length" function from the LT Extension addon utility.
LT
16.12.2005    102465×
Prices - CAD eShop:
applies to: AutoCAD LT ·
Tip 12479:PkLength - export line lenghts to Excel.
Tip 826:How to sum up lenghts of all lines in AutoCAD LT drawings?
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
