  Visitors: 5016
CAD tip CAD tip # 4793:
Dimetry - dimetric projection of AutoCAD 3D objects.
A - answer By default, AutoCAD offers only isometric and perspective projections. For dimetric representation of 3D scenes you can use the free utility by CAD Studio - DIMETRY. Dimetric projection (as a special case of axonometric view) employs projection angles of about 7/42 degrees.
This application can be downloaded from Download.
See also the military projection 30/60 - VOJPER.
ACADMDTADT
22.12.2005    20217×
Prices - CAD eShop:
applies to: AutoCAD · MDT · AutoCAD Architecture ·
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 13173:How to convert projection of a 3D model to a 2D DXF drawing?
Tip 12569:How to Explode a ViewBase generated from a 3D model?
Tip 12053:Analysis of stability - will it upset?
Tip 11823:Associative dimensions in drawing views of a 3D model in AutoCAD.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
