  Visitors: 7068
CAD tip CAD tip # 4826:
Common label for multiple rooms in Revit.
A - answer If you want to handle a group of rooms as a single room (labels, selection, schedule...) disable the Bounding property for their common boundary walls.
See: Wall > Properties > Room bounding.
Revit8
16.1.2006    7095×
Prices - CAD eShop:
applies to: Revit 8 ·
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13408:How to increment the numbers in DWG texts by a specified value, e.g. +1, +10?
Tip 13220:RangeSel - select blocks by the range of their attribute values
Tip 11982:Creating table with parcel numbers and areas - AreaTab.
Tip 11350:How to renumber Revit rooms in a given order?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
