  Visitors: 10035
CAD tip CAD tip # 4833:
How to set the location of AecLayerStd.dwg?
A - answer If your Architectural Desktop reports **File Not Found** or if you want to change/move the layer key file to a folder other than the default C:\Documents and Settings\All Users\Application Data\Autodesk\ADT 2006\enu\Layers, use the command AecDWGsetup > Layers.
ADT2006ADT2005ADT2004
20.1.2006    8150×
Prices - CAD eShop:
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 12429:HatchOverlap - check for any overlapping hatches in a DWG
Tip 12287:AutoCAD hatch flood-fill does not honor all boundaries.
Tip 10693:List of blocks (incl. nested blocks) used in a DWG drawing.
Tip 9694:Random object colors in 3ds Max.
LogOff 2006 More info
