  Visitors: 5522
CAD tip CAD tip # 4890:
How to change a color DWF underlay to black-and-white?
A - answer If your underlaid color DWF is hard to read, you can easily change it do display as monochrome. Use the DWFADJUST command, select the DWF underlay and choose Monochrome, Yes.
You can also set Monochrome in its Properties window (Ctrl+1).
ACAD2007ADT2007Map2007
1.3.2006    14905×
Prices - CAD eShop:
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 10759:How to publish a DWG to a PDF file without attaching "-Model" to its name?
Tip 10517:How to enable/disable automatic display of PDFs published from Inventor?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
