  Visitors: 3987
CAD tip CAD tip # 4925:
How to copy named filters to another computer?
A - answer Definitions of named filters defined in the FILTER command are saved to the text file filter.nfl. This file is located in the local working directory (e.g. C:\Documents and Settings\username\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\Support\filter.nfl).
To copy the definitions between PCs copy this file or a part of its content.
ACAD
23.3.2006    5525×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12997:Hiding Revit dimensions smaller than...
Tip 12228:How to set decimal precision (number of dec.places) for Inventor 3D Annotations?
Tip 12215:How to change truecolor DWG objects to indexed ACI colors?
Tip 12210:How to erase a specific object type in all DWG layouts?
Tip 11654:Select 3D solids by their height, volume, surface (smaller then...)
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
