  Visitors: 5179
CAD tip CAD tip # 5011:
Accessing old versions of the IMAGE and XREF commands.
A - answer AutoCAD 2007 introduced a centralized External References Manager which also takes over (is mapped to) the standard IMAGE and XREF commands. If you want to use the old classic dialogs of these two commands, you can use the commands CLASSICIMAGE and CLASSICXREF respectively.
The commandline versions -IMAGE and -XREF are not influenced.
ACAD2007LT2007
10.5.2006    12290×
Prices - CAD eShop:
applies to: AutoCAD 2007 · AutoCAD LT 2007 ·
Tip 13435:Bulk setting of layer properties according to the object in that layer.
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 12977:Easily find CAD/BIM document references (including missing ones) - Reference Explorer
Tip 12705:How to disable osnaps for xref objects?
Tip 12361:Seamlessly connected images by irregular clipping in AutoCAD (or LT).
