  Visitors: 4325
CAD tip CAD tip # 5043:
Missing icons when transferring AutoCAD menu from an older version.
A - answer In AutoCAD 2002 (or older), you have used internal icons of AutoCAD commands (e.g. ICON_16_DIMRAD) in your customized user menus. These icons do not work now (are replaced by question marks or clouds) in higher AutoCAD versions (2004, 2005, 2006, 2007...).
Internal icon names have changed in menu files of the version 2004 (and higher) - they are now in the format RCDATA_16_xxxxxx.
When you transfer your menus, change (e.g.):
ID_Dimradius [_Button("Radius dimension",ICON_16_DIMRAD,ICON_32_DIMRAD)]^C^C_dimradius
to
ID_Dimradius [_Button("Radius dimension","RCDATA_16_DIMRAD","RCDATA_16_DIMRAD")]^C^C_dimradius
ACADLT
29.5.2006    14377×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 12287:AutoCAD hatch flood-fill does not honor all boundaries.
Tip 12120:Double-click to edit raster images in DWG drawings.
Tip 11450:How to run Fusion 360 in a web browser? (URL)
Tip 11398:Editing block attributes in AutoCAD mobile.
Tip 11365:How to store Fusion 360 models directly to Fusion Team projects?
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
