CAD tip # 5063:
Tip 13873: | How to load GeoJSON data into AutoCAD, Map, Civil 3D, Infraworks? |
Tip 13604: | Importing points from a Shape file as symbols/blocks mapped to object data. |
Tip 13522: | LookupXLS - populating DWG texts from Excel spreadsheets. |
Tip 13426: | Use of alternative units for arithmetic in dimensions (without square brackets). |
An image inserted in Map is not georeferenced. « | » Which version of PDF files is generated by AutoCAD 2007?
Featuring: Increase your productivity with our set of add-on functions for AutoCAD Civil 3D CADstudio Civil Tools ![]() |
