  Visitors: 12852
CAD tip CAD tip # 5077:
Copy/Paste fails in a DWG2000 file saved from AutoCAD 2007.
A - answer When you open a DWG file (in the DWG2000 format), saved from AutoCAD 2007, in AutoCAD 2000, 2000i, or 2002, the clipboard functions Copy, Cut and Paste and WBlock/Insert may fail.
Apply the ACDB17.DLL fix for AutoCAD 2007 - see Download.
You can also apply the DL7450124 hotfix for AutoCAD 2007 (or related CAD application), or the Service Pack 1 (or higher). Then resave the DWG file to the R14/2000 format. This applies also for the Autodesk DWG TrueConvert.
To find the affected DWG files you can use the "2000 from 2007 Find Utility" (see the hotfix).
ACAD2007ACAD2000ACAD2002R14ADTDWG
16.6.2006    28270×
Prices - CAD eShop:
Tip 13933:How to set grid colors in AutoCAD Web?
Tip 13246:I can't copy/paste a block from AutoCAD into an Inventor drawing.
Tip 12641:How to copy a graph from Excel to AutoCAD?
Tip 11994:How to scale a 3D model to a given size in Fusion 360?
Tip 11967:How to apply a changed drawing template (DWT) to existing drawings?
LogOff 2006 More info
