  Visitors: 7172
CAD tip CAD tip # 5106:
How to convert MDT parts to AutoCAD 3D solids?
A - answer You can just use the EXPLODE command or a conversion through ACIS - the AMACISOUT command in Mechanical Desktop and ACISIN in AutoCAD.
MDTACAD
10.7.2006    9613×
Prices - CAD eShop:
applies to: MDT · AutoCAD ·
Tip 12588:Which CAD formats can be be translated in Fusion 360 even without the cloud, offline?
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
Tip 9528:Using Autodesk Fusion 360 as a CAD converter.
Tip 9222:CAD formats exported from Inventor Fusion 2013.
