CAD tip # 5112:
applies to: AutoCAD Architecture 2007 · AutoCAD · |
Tip 11469: | Why you should not use the DEFPOINTS layer to draw geometry? |
Tip 9276: | AutoCAD reports some xrefs as "Unresolved". |
Tip 7463: | One or more objects in this drawing cannot be saved to the specified format. |
Tip 5342: | Errors found in references to other objects |
Tip 4666: | Batch recover and batch audit DWG drawings. |
A closed polyline cannot be extruded.
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
