  Visitors: 5848
CAD tip CAD tip # 5146:
Making 3D DWG files smaller.
A - answer By setting the SOLIDHIST variable to 0 you can make your DWG files (containing edited 3D solids) a bit shorter.
In a default setting, AutoCAD saves the editing history of 3D solids - i.e. the individual creator-objects (intersection, subtract...) for easier later re-editing. If you don't need this history, you can disable it using SOLIDHIST, with the BREP command or through the "History" setting in the Properties window (Ctrl+1).
ACAD2009ACAD2008ACAD2007
2.8.2006    20858×
Prices - CAD eShop:
applies to: AutoCAD 2009 · AutoCAD 2008 · AutoCAD 2007 ·
Tip 14088:3 methods of creating true rectangles in AutoCAD.
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13868:XrefStamp - create a dynamic list of xrefs in your DWG drawing.
Tip 13847:Pringles in AutoCAD - a hyperbolic paraboloid.
Tip 13773:What is the maximum paper size when plotting from AutoCAD?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
