New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 5197:
Question
AutoCAD blocks inserted with MINSERT cannot be exploded directly.
But you can use a combination (sequence) of the FLATTEN and EXPLODE commands to explode a "multiple-insert" block reference (Flatten is a Express Tools command).
To explode a combination of anonymous and MInserted blocks (e.g. from LockDWG or Deter) you can use the ExplodeM utility - see Download.
ACAD
13.9.2006    54246×
applies to: AutoCAD ·
Tip 14361:Extended ATTOUT/ATTIN for block attribute management in Excel (also for LT).
Tip 14163:How to select DWG texts containing a certain number of characters?
Tip 14098:How to use arc length parameter in Inventor sketch?
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13056:How to copy DWG Properties from one drawing to another?
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
