  Visitors: 7763
CAD tip CAD tip # 5200:
How can I use vehicle traversion paths in AutoCAD?
A - answer The AutoTURN add-on application for AutoCAD can help you interactively design roads, crossings, roundabouts, cul-de-sacs and urban plans. It can simulate vehicle maneuvers, sweep paths and transition curves for most vehicle types, incl. cars, trucks, multi-axle semi-trailer and aeroplanes.
See details on Transoft Solutions web site.
Since 11/2013 you can also use Autodesk's own "Autodesk Vehicle Tracking" application for AutoCAD and AutoCAD Civil 3D.
ACADCivil
15.9.2006    19648×
Prices - CAD eShop:
applies to: AutoCAD · Civil 3D ·
Tip 12988:Where are Autodesk Infraworks building, road and terrain models loaded from?
Tip 10383:The shortest path between two points on a network.
Tip 9020:Three methods and three different results of measuring distance in a map.
Tip 8597:Flashing, patchy appearance of Revit 3D models in Showcase.
Tip 7852:Put Google Earth maps directly into AutoCAD.
