  Visitors: 5870
CAD tip CAD tip # 5243:
Batch convert Civil 3D drawings to plain AutoCAD DWGs.
A - answer Autodesk Civil 3D 2007 offers an embedded "drawing batch converter". You can find it in the File menu or under the CIVILBATCHCONVERTER command.
This function can change units in multiple drawings, explode Civil objects to simple AutoCAD entities, convert DWG file formats, bind xrefs, etc. You can add prefix or postfix to the processed file names.
Civil2007
21.10.2006    15596×
Prices - CAD eShop:
applies to: Civil 3D 2007 ·
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 10808:How to make transparent icons for my CUI ribbon in AutoCAD 2017.
Tip 10576:How to batch convert lines and arcs to polylines?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 10201:Inventor is slower opening files in older formats.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
