  Visitors: 6670
CAD tip CAD tip # 5283:
Points do not reflect the PDMODE and PDSIZE settings.
A - answer If POINT-type objects do not react to the display format settings and display only as dots in your drawing, make sure they are not placed in the layer DEFPOINTS. Points in the special layer "DEFPOINTS" are always displayed as dots.
ACADLT
21.11.2006    10697×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 12705:How to disable osnaps for xref objects?
Tip 11469:Why you should not use the DEFPOINTS layer to draw geometry?
Tip 9153:Arrowheads or other parts of dimensions are not printed.
Tip 9090:Why are suppressed table borders still displayed?
Tip 7565:Where from comes the layer $AUDIT-BAD-LAYER ?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
