  Visitors: 3334
CAD tip CAD tip # 5303:
Cannot draw perpendicular to some Arcs.
A - answer If you use rotated UCS or if you export DWG from some vertical applications (like Civil3D or ADT), some right-hand arcs may be represented with a switched normal (rotated normal vector [X,Y,Z]=[0,0,-1]). With such "backside" arcs you cannot e.g. draw perpendicular lines (PER osnap) or you may find othe problems.
To normalize such arc to the standard format (normal vector [0,0,1]), you can use the free LISP utility - Xanadu ArcNorm - for dowwnload on www.cadstudio.cz/download (load it by APPLOAD, start it by ARCNORM). This command selects all switched arcs and make their direction normal (without visual changes in the DWG file).
CivilADTACAD
6.12.2006    8893×
applies to: Civil 3D · AutoCAD Architecture · AutoCAD ·
Tip 7341:How to scan all DWG drawings for missing SHX files?
Tip 6933:How to show history of drawing entities?
Tip 6724:Automatically generated picture-legend of drawing blocks.
Tip 6598:How to detect all DWG files containing Xrefs?
Tip 6146:How to detect DWG files containing VBA macros?
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
