  Visitors: 4336
CAD tip CAD tip # 5319:
How to set two attributes in a block always to the same value?
A - answer For linking attributes you can use a dynamic field for lookup values. In the BEDIT block editor set the attribute preset value for both attributes to a field Block placeholder > Lookup, in the lookup table set the predefined values.
After you insert such block and select its predefined values (blue triangle), both attributes are set to identical values. See an example of such block - AutoAtt in Blocks library > Popisky/Labels (this sample block also automatically displays the name of the layer it is inserted into).
You can also make use of the dynamic linking in the CADstudio LiveLabel utility.
ACAD2010ACAD2007ACAD2006
17.12.2006    18782×
Prices - CAD eShop:
applies to: AutoCAD 2010 · AutoCAD 2007 · AutoCAD 2006 ·
Tip 13740:Dynamic label with filesize of the current DWG file.
Tip 13599:How to read iProperties from Inventor models and drawings in AutoCAD DWGs?
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13000:Labels of dimensional parameter values in dynamic blocks (parameters->attributes)
Tip 12685:ReLinkField - re-link fields to source objects.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
