  Visitors: 5023
CAD tip CAD tip # 5321:
How to model a 3D spiral in Inventor?
A - answer If you need to model a 3D spiral in Inventor (e.g. a 3D pipe path, own spring type, wind up a hose or cable on a reel, etc.) you can use the "Project to Surface" function in 3D sketch. You can wrap an angled line on a cylindrical surface.
Then you can sweep a profile along this 3D path or generate a wire or pipe system.
(if you need a bended spring along an arc - see the Block Catalog)
Inventor11InventorPro11
18.12.2006    32440×
Prices - CAD eShop:
applies to: Inventor 11 · InventorPro11 ·
Tip 13653:FPoly - draw fixed-length polylines in AutoCAD.
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 10708:Modeling compression injection screw for molding machine.
Tip 10459:How to change the number of parallel treads on spiral stair?
Tip 10432:How to open files in A360 Drive from Inventor or any other application?
