  Visitors: 11868
CAD tip CAD tip # 5334:
How to schedule areas of non-closed spaces in Revit?
A - answer Switch on the Room and Area panel (right-click in the left toolpanel). Now use the Room separation tool and draw lines enclosing the spaces which are not separated by walls.
Such "rooms" can be now scheduled and their areas calculated.
Revit9
2.1.2007    6288×
Prices - CAD eShop:
applies to: Revit 9 ·
Tip 13566:Text size in Revit temporary dimensions.
Tip 11349:How to list Revit room areas by the DIN 277-1 standard?
Tip 10402:How to easily repeat last command in Revit?
Tip 9998:Automatically rotate drawings plotted from Revit or other software.
Tip 9731:Revit filled region doesn't mask the underlying geometry.
