  Visitors: 4783
CAD tip CAD tip # 5342:
Errors found in references to other objects
A - answer The REFEDIT command reports:
Errors found in references to other objects:
** Application reference missing: ACAD, to AcDbBlockTableRecord.
(or AcDbLinetypeTableRecord)
Perform an AUDIT of the main and the reference (block) drawing. The DWG file(s) is probably corrupted, or it may be improperly saved back from a higher version, or an object enabler may be missing, or it may come from a non-Autodesk CAD application (a faked DWG format file). Check also possible nested xrefs of the xref.
ACADLTADT
4.1.2007    22159×
Prices - CAD eShop:
Tip 5077:Copy/Paste fails in a DWG2000 file saved from AutoCAD 2007.
Tip 3495:Fatal error - cannot find xmx file acdbenu.xmx (acdb???.xmx)
Tip 1214:How to get the "prompt" property from "attribute" objects in VBA?
LogOff 2006 More info
