  Visitors: 4123
CAD tip CAD tip # 5377:
Two undocumented commands in AutoCAD 2006/2007.
A - answer AutoCAD version 2006 (and higher) contains two undocumented commands which update the attribute extraction tables (EATTEXT).
The EATTEXTEDIT command allows to edit the definition of the extracted table (manual attribute edit, adding new attributes). Select the extracted table before starting this command.
The EATTEXTUPDATE command invokes update of the extracted table, e.g. after changes performed in attributes of the drawing blocks. This command is equivalent to the the Update function in the table context menu. Select the table before starting this command.
ACAD2008ACAD2007ACAD2006
23.1.2007    13089×
Prices - CAD eShop:
applies to: AutoCAD 2008 · AutoCAD 2007 · AutoCAD 2006 ·
Tip 6289:How to export X-Y-Z coordinates of AutoCAD drawing blocks?
Tip 6006:How to extract co-ordinates at certain intervals along the length of a line?
Tip 5384:How to insert blocks at each polyline vertex (or just at endpoints)?
Tip 4566:BOM in plain AutoCAD.
Tip 4053:"Invalid field specification" trying to ATTEXT a SDF/CDF file
