  Visitors: 6651
CAD tip CAD tip # 5477:
Easily connect 3D points in Civil 3D.
A - answer AutoCAD Civil 3D allows (anywhere it asks for a coordinate) to use a transparent command returning the coordinate from the point number (PN) or from the point name (PA).
E.g. if you have the following points in the points list of your drawing/project:
numbernamecoordinates
11point11XYZ1
12point12XYZ2
13point13XYZ3
14point14XYZ4
15point15XYZ5
You can e.g. draw a line from the 2nd to the 3rd point with:
_LINE 'PN 12 [esc] 'PA point13 [esc] [enter]
But you can also create quickly a 3D polyline going through (connecting) the whole series of points - with a single simple command:
_3DPOLY 'PN 11-15 [esc] [enter]
Civil will even skip possible missing points in the specified series (from-to).
Civil2008Civil2007
23.3.2007    25855×
Prices - CAD eShop:
applies to: Civil 3D 2008 · Civil 3D 2007 ·
Tip 14061:Animated drawing of geometry in AutoCAD.
Tip 14056:How to move blocks in the Z axis to the terrain model surface?
Tip 14017:Voronoi diagrams in AutoCAD.
Tip 13967:Drawing polylines using arbitrary length units - 2DpolyC.
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
LogOff 2006 More info
