  Visitors: 4002
CAD tip CAD tip # 5502:
How to set PSLTSCALE globally for all layouts?
A - answer The PSLTSCALE variable setting is layout specific. If you need to set this variable to 1 or 0 in all your layouts you can use the following code:
(foreach lay (layoutlist)(command "_LAYOUT" "_Set" lay "PSLTSCALE" 1))
or
(foreach lay (layoutlist)(command "_LAYOUT" "_Set" lay "PSLTSCALE" 0))
ACAD
4.4.2007    24067×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 2699:How to automatically switch to a different LTSCALE in layouts?
Tip 1041:Why are complex linetypes scaled properly only in the modelspace and not in the paperspace/layouts?
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
