  Visitors: 5778
CAD tip CAD tip # 5510:
Using symbol libraries for markups in Design Review.
A - answer For markups of CAD files (review cycle using DWF) you can use not only the default internal symbols but also your own user symbol libraries (catalogs).
You can easily make your own symbol catalogs. Just open your drawing containing the blocks (with symbols) in AutoCAD and use the PUBLISH command to convert it to a DWF file. Such "library" DWF file can be then loaded in Design Review with the command "Import DWF as Symbol Catalog" (under the stamp icon).
  1. In the AutoCAD's Publish dialog select just the Model sheet of your catalog DWG drawing (with inserted blocks).
  2. With the "Publish options" button start the options dialog and in the "DWF data options" field set the "Block information" value to: Include.
  3. Create a new "Block template file" (the next line).
  4. In the dialog "Publish block template" click the "Scan for Blocks" button and then confirm the blocks (and their properties) for publishing (use the "Name" property).
  5. Confirm the Publishing options (OK).
  6. Start the DWF publishing with the Publish button.
  7. Load the resulting DWF file into Design Review ("Import catalog" under the "stamp" tool).
The published blocks can be then simply inserted as activeshape objects into the redlined CAD drawings and then sent back to the authors for re-reading into AutoCAD and performing the requested changes.
Design Review - symbols
As a sample of such symbol library you can use the DWF file "Znacky" (traffic signs) created from the traffic signs drawing from the CAD blocks catalog. You can download the Znacky.DWF file from the section Vertical traffic signs of the Block catalog.
ACAD2008ACAD2007ACAD2006LTDWF2008DWF2007
13.4.2007    22738×
Prices - CAD eShop:
Tip 13026:How to switch Vault to the Forge-based CAD viewer "Autodesk Viewer"?
Tip 11835:Shared Views to your DWG drawings - easy collaboration with collegues and clients.
Tip 11359:An updated Autodesk Design Review for Windows 10.
Tip 10258:Digital signature of CAD files in the DWFx format.
Tip 10051:How to save from AutoCAD or Inventor to Dropbox, Google Drive or OneDrive?
